Panasonic SD or HD?
Discussion in 'Panasonic TVs Forum' started by rubberducker, Aug 16, 2004.
  1. rubberducker
    rubberducker
    Aug 10, 2004
    345
    i am completely new to plasmas, but after nine years or so with my phillips widescreen, i have decided to go for a plasma.
    i have taken the collective wisdom of these boards to heart and am going to go for a panasonic.
    i am however, unsure which to go for SD or HD. i would like to future proof myself for ten or so years, and i am really into video games (perhaps more than dvd's, but only just!). i am not sure i could even afford the HD and would have to wait until they came down in price a little (is that likely?).
    one of my main considerations is the next genaeration of playstations and xbox's (which are right around the corner) and my current modded xbox. i have read all sorts about progressive scan etc - which sounds like exactly the picture improvement i am after (my current rgb picture is awful through my phillips).
    does anybody else have these requirements in mind, or know anything about the specs? any help would be greatly appreciated....
    :thumbsup:
  2. AlexMac
    AlexMac
    Jun 9, 2004
    55
    Paisley
    +4
    Hi Rubberducker,
    I looked at the same options as yourself and opted 2 weeks ago for the HD model. With HDTV coming in a 18 months or so plus the better gaming options i thought it would be worth the extra £1000 or so. I have my PS2 linked in with the Ixos component cable and games look great. I am still running the screen on low settings until i go over 200 hours but still looks the part. I'm thinking of getting a US version of Xbox next with the hidef kit, apparently amazing detail. DVD's look great on it as well from a component source.
    Speak to the guys at AV Sales, their still doing a deal on the HD with board and stand for just over £3200. In the long term i think you will benefit by going for the HD.
    Alex
  3. Piers
    Piers
    Dec 11, 2002
    1,994
    Cheshire
    +230
    Rubberducker
    The SD version very happily accepts a prog scan signal. The HD is better with an HD signal but with an SD signal there is little in it.
    Piers
    Home Cinema Engineering
    www.homecinemaengineering.com
