Panasonic SCHT900 Speakers
Discussion in 'Home Cinema Buying & Building' started by wrighty, Sep 20, 2004.
  1. wrighty
    wrighty
    Does anyone know whether the Subwoofer and Speakers for the SCHT900 system are compatible with any other DVD player other than SAHT900 head-unit supplied? I've had mine stolen and I'm left with the some fairly inert and depressing speakers.
  2. bobbypunk
    bobbypunk
    speakers will work but will probably sound worse than they did with your old system even with a reasonable seperate amp! The sub will not work with anything else unless you get a detailed wiring description from panasonic and then it wouldn't necescerily be possible!!
