Panasonic scht900 and tx36pd30 problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nasgul, Oct 17, 2003.
  1. Nasgul
    Nasgul
    I recently purchased a Panasonic tx36pd30 tv and a scht900 dvd/ surround system.
    I have been very pleased with both, except for one problem.
    If I play DVD's (i.e. attack of the clones/ blade runner) using a component connection, the picture will jump every so often.
    If I use the RGB Scart cinnection the problem does not seem to occur.
    I am keen to use the component connection, as I beleive this improves picture quality. I am using a brand new IXOS component lead, 3 rca to 3 rca. I do get a good picture, but this jumping occurs erratically.
    I'm not sure if it is the TV/ DVD or lead ?
    Any help would be appreciated.
    I have also emailed Panasonic, so hopefully I will get some feedback from them.
    Thanks,
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Who did you buy from? do you have another component source? Xbox etc that you can try to see which one is playing up? Does it jump while watching a film? could be a sync issue but not sure what is the cause.
