Panasonic SCHT520 Problem
Discussion in 'Home Cinema Buying & Building' started by jakec, May 11, 2005.
  1. jakec
    jakec
    I've just purchased a Panasonic SCHT520 Home Cinema System to use with my 32" Philips Widescreen TV (Model 32DW6559) and I am having problems with the TV switching between the AV1 and AV2 socket for no reason. :(
    If I am in the setup menu on the SCHT520, or I have the system turned on but no disc inserted is keeps switching between the TV channel and back to the SCHT520 screen. As soon as the DVD starts playing it is fine!
    The SCHT520 is plugged directly into AV1 and the Freeview box is plugged into AV2. If I switch them over I get the same problem.
    I suspect that it is a setup problem, but have run out of ideas and the manuals are not much help.
    Any help would be gratefully appreciated and if you require any further information please do not hesitate to ask.
    :lease:
    JAKEC
