PANASONIC SCHT520 or PIONEER DCS-323?
Discussion in 'Home Cinema Buying & Building' started by asteroid, Nov 29, 2004.
  1. asteroid
    asteroid
    Hello, I am new to home cinema and I was wondering if anybody could tell me which of these two home cinema systems (PANASONIC SCHT520 or PIONEER DCS-323) give the better sound quality (not necessarily the loudest)? And also which is best overall?
    Thankyou
  2. Orson
    Orson
    Feb 21, 2002
    3,311
    Sunny Ilson, pride of Derbyshire!
    +675
  3. asteroid
    asteroid
    Thanks. The panasonic does seem better. The only problem is that it doesn't have a digital in for the connection of my xbox. Does this mean that I wont be able to take advantage of the 5.1 sound that my xbox can have?
  4. Orson
    Orson
    Feb 21, 2002
    3,311
    +675
    Nearly missed that post, sorry.
    Yes, I believe that to be correct, I have had the same consideration with my Gamecube, but the type of games that get played on it won't really make any difference, and that's only if they support 5.1 of course.
    That, and the fact that Richer Sounds are doing the Multiregion version for £179 swayed me :D
  5. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
    I have an xbox and as far as i am aware it does not have a digital audio out, my ps2 does however. Am i correct or just going blind.
  6. ZAP263
    ZAP263
    Aug 23, 2004
    61
    You're right but you have to purchase an Xbox Advanced Scart Cable and that has an optical out on it.
