Panasonic SCHT17 Package - any good
Discussion in 'Home Cinema Speakers' started by busterdan, Aug 26, 2005.
  1. busterdan
    busterdan
    Aug 18, 2004
    1,346
    48
    SE London
    +37
    I really appreciate any feedback or links to reviews on the Panasonic SCHT17 package...
    I am after some reasonable speakers with an amp that has at least two optical inputs as well as two component inputs... for the money... (around £300) this set seems a pretty safe bet but I thought I'd check before committing to buy...
    I'd also consider something cheaper if it had the inputs.... I only have a small room so 1000watts is maybe overkill :)
    Thanks for your help
