tall.small
I am currently a experiencing interference from my SCDT100.
It is connected to my Panasonic tx28pl1 by decent s-video cable (can't remember the name off hand) and it also has interconnects connecting to the TV so I can listen to the TV through the system.
However, when I play DVD's i notice bad interfernce lines on the screen. But it seems when I disconnect the interconnects from the TV sound source the problem goes away. But (!) the problem seems to be the actual DVD player part. Its seems to be when it is spinning to access the DVD disc the interference lines appear.
I have disconnected and reconnected all cabling so to eliminate bad connections.
Anyone offer any advice. Sorry if the above query sounds a bit confusing.
Thanks.
Thanks.
