jamest1987
- Joined
- Sep 28, 2008
- Messages
- 8
- Reaction score
- 0
- Points
- 4
- Age
- 36
I am looking at getting the Panasonic SC-PT460EB to go with the Panasonic TH-42PZ80B but having read some reviews it looks like the cables are a little short for the rear speakers and are hard wired so can't be extended without some DIY work.
I like the look of the features on the unit but the short cable (probably poor quality cable?) is putting me off a bit.
Are there any similar units that I can add some speakers and subwoofer to for a similar price (~£200)? Would be good to be able to get some good cable that I can cut to the right length to fit the room.
