Panasonic SC-HT900 multiregeon hack?
Discussion in 'Home Cinema Buying & Building' started by Tiiti, Oct 20, 2003.
  1. Tiiti
    Tiiti
    Hello all,
    Just bought this system yesterday and I love it! Icing on the cake would be to unlock it. Anyone any idea on how I can?
    Many thanks
  2. blackbull
    blackbull
    I don't know if you can I own a 900 aswell and before that a SC-HT70 and I found no hacks for any Panasonic DVD players on the net so when I replaced it with a new betterspecced model I made sure I went for a multi region 900. How much did you pay, a multiregion is only £430 from Techtronic maybe you can take it back, I know its unlikely but you may be lucky, and replace it with a multi region model. Sorry I can't be more positive.
  3. Tiiti
    Tiiti
    Thanks blackbull. I don't fancy taking it back to be honest, I can't part with it now :) I guess it can be chipped though so I'll have to look in to that.
  4. blackbull
    blackbull
    Well Techtronic are as good as anyone else. Happy viewing Region 2 or otherwise.
  5. alfablue
    alfablue
    Aug 16, 2002
    287
    19
  6. Chris23
    Chris23
    Apr 14, 2004
    274
    +7
    Can someone actually confirm that this works with no nasty side effects please?
  7. outtathaway
    outtathaway
    Dec 2, 2003
    40
    2
    11
    huddersfield
    Worked fine for me although it took ages for the remote to arrive and remember you only get one shot at it.
  8. 127pjsny
    127pjsny
    I hope you have better luck with youe Panasonic than I did. My Panasonic SC-Ht80 has stoped reading DVD's.
  9. durden-soap
    durden-soap
    I CAN RECOMMEND WWW.DVDCODES.NET
    FOR SONY, PANASONIC & TOSHIBA, SIMPLE MOD & TOP SERVICE.
