Panasonic SC-HT520 advice required please.
Discussion in 'Home Cinema Buying & Building' started by Rapid 17, Jul 8, 2005.
  1. Rapid 17
    Rapid 17
    Jan 14, 2005
    896
    28
    +79
    Hi there folks. I have a Panasonic SC-HT520 home theatre system connected to Panasonic PV500B plasma TV. I only took delivery of the plasma this week together with a Panasonic DMR-ES10 DVD recorder. The DRM-ES10 gives a better picture quality than the SC-HT520 player. Is there any way that i could use the DVD recorder/player in place of the dvd player in the HT520 system ? The player in the HT-520 system is connected to the sub woofer/amplifier with what looks like mini scart type plugs. The ES10 DVD recorder/player doesn't have that type of plug or socket. The mini scart type plugs have 6 + 6 pins in the top row and 13 pins in the bottom row. Is there any type of lead on the market that solve this problem please ? Many thanks, Geoff.
