Panasonic SC-HT37R Audio Sync problem
Discussion in 'Home Cinema Buying & Building' started by Borris_UK, Jul 23, 2005.
  1. Borris_UK
    Borris_UK
    Jul 23, 2005
    2
    Hi all,
    Not sure if anyone can help me but...
    I have a Panasonic SC-HT37R kit which I have had for about 6 months now. It's all connected up properly for scart recording / playback and I am using the supplied optical cable to connect the DVDR to the Amp.
    When I playback audio through the TV (via Scart lead) everything is great.
    When I playback through my Amp and external speakers I get about a half second delay on the audio which throws the lipsync out. As mentioned above, the Amp is connected using the optical cable AND a scart lead to the DVDR and the speakers are connected to the Sub which is connected to the Amp using the supplied 'special' cable.
    I haven't tried using s-video with phono leads yet but would prefer it if I could get it to work using the scart setup as detailed in the manual.
    Any ideas would be greatly appreciated.
    Mike
