Panasonic SC-HT25R Query?
Discussion in 'Blu-ray & DVD Players & Recorders' started by StevieC, Oct 30, 2004.
  1. StevieC
    StevieC
    I've decided to upgrade my Sony DAV-500 for a DVD recorder and after viewing posts on this forum think I'll go for the Panasonic SC-HT25R (unless anyone has a good reason to steer clear of it?).
    One of the problems I currently have with DVD's is my 2 year old getting hold of her Lion King collection and scratching them to the point they no longer play properly.
    My query is this .. is it possible to record DVD's to the HDD of the Panasonic and then save them to DVD-R so I can rattle off a couple of copies and keep the original DVD safe from the jam covered fingers of my 2 year old?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,877
    Warwick
    +2,790
    Afraid not - no DVD recorder will let you do this - however you could hook up a second DVD player to the E85 and copy it that way. You will need a copy protection disabling Scart for that though - others can give advice on that.
  3. StevieC
    StevieC
    So I could use my existing Sony DVD player and link it to the new panasonic one, sounds a reasonable solution.
    Any bad feed back on the SCHT25R package?
