Panasonic SC-HT1500 component output
Discussion in 'Home Cinema Buying & Building' started by mishmash, Jun 14, 2005.
  1. mishmash
    mishmash
    May 23, 2005
    144
    Cornwall
    +9
    Basically I am trying to play my DVD through the component outputs which will enable a progessive scan to be display on my Sagem HD-D45, however I do not get a signal. I am not sure if the problem lies with the DVD player or my TV.
    S-Video and SCART both work fine but for the best picture I would like to get a progressive output. I have tried three different component cable, a QED, Profigold and Chord (kind AV shop lent me the cables to test)
    I have RTFM to death but am at a bit of a loss at the moment. Any help would be appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you need to go into the set up menu and enable YUV this disables scart output to get Component out of a 1500 IIRC
  3. mishmash
    mishmash
    May 23, 2005
    144
    Cornwall
    +9
    Thanks for the reply. DO you know where in the setup menu I can find this option, I have had a look but can't locate it. I can only find and option to turn progressive on and off.
  4. Ben_S
    Ben_S
    I've not got my kit in front of me, but from memory there is a setting in AV2. Two output settings have "(with component)", the other does not - sorry can't remember the exact option. Although you are not using the AV2 scart output it does seems to have an effect.
    Might work.......
  5. mishmash
    mishmash
    May 23, 2005
    144
    Cornwall
    +9
    Tried that option. You have the choice of Video (with component), S-Video (with component) and RGB (without component). Didn't make any difference no matter what setting I used.
  6. mishmash
    mishmash
    May 23, 2005
    144
    Cornwall
    +9
    Sorted now guys. I took the player to a local AV shop and they confirmed that the player is not outputting any component signals so it's back to the shop it goes.
