Panasonic SAXR45 opinions
Discussion in 'AV Receivers & Amplifiers' started by fuglyface, Jun 22, 2003.
  1. fuglyface
    fuglyface
    Looking at buying my first AV receiver.
    Really fancy the Panasonic SAXR45 but cannot find any reviews on it.
    Anybody got one Eany opinions
    The manual says it has a selectable second line out for an amp in another room.
    Could this be used the same as pre outs for my onkyo stereo amp that has pre in/outs.
    Fuglyface
  2. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    I am interested as well in buying the Panasonic SA-XR45 AV receiver to replace my old Panasonic SAHE70 and was wondering where you can look at the manual, I checked the panasonic.co.uk site but did not find it, Can you share your source of the manual, Either reply or PM thanks.
  3. fuglyface
    fuglyface
  4. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    Cheers for that.
