Panasonic Sa-ht80
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nick100, Mar 15, 2002.
  1. Nick100
    Nick100
    Is there a hack for my HT80 or does it need an upgrade to play multi-region. Can't get it to play cdrs as well any way round this :confused:
  2. MarkHT80
    MarkHT80
    I have just spoken to a local retailer who says that there is an upgrade for multi region (the warranty will be invalidated!), however the machine (SA-HT80) does not and cannot play CD-R's, VCD's etc. as the laser technology doesnt allow for these formats!
    Looks like we are both in the same boat as I would like to play the same formats, in particular, Video's captured on my DV Video camera and recorded onto CD-R.
    Can anyone else suggest a fix?
  3. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    Location location location
    +94
    Theres no actual "hack", but it can be modded by a DIY chip, or a software upgrade if taken to the appropiate dealer.
    It won`t read CD-R discs, though. Panasonic models at this time did not have CD-R abilites, only the 2001 range onwards (HT70).
    Hope that helps?
