panasonic sa-ht75
Discussion in 'Blu-ray & DVD Players & Recorders' started by derek1964, Jan 20, 2004.
  1. derek1964
    derek1964
    looking for hack for panasonic sa-ht75 looked everwhere on the net but no joy.
  2. bobbypunk
    bobbypunk
    search under sc-ht75
  3. bobbypunk
    bobbypunk
    Found this on a site www.dvdrhelp.com
    Haven't tried it and don't know where to get the firmware?!? but here it is anyway.
    "You can make this DVD player region free using Panasonic Service Disk #2 and the following instructions:
    INSERT DISK- and confirm "STOP" is displayed...
    USING THE REMOTE press "SETUP"
    Go to "DISPLAY" menu
    Select "ON SCREEN MESSAGES" then press "ENTER" button
    Press ">10" found on the bottom right coner
    Press "6" button
    Press "4" button
    Press "3" button
    Press "8" button
    A PASSWORD WINDOW SHOULD APPEAR
    TYPE IN "3192"
    PRESS THE "ENTER" BUTTON TWICE
    You wil see RESET-DVD in the display and after this the disk will be read and the HT-SC75 is Region Free.
    When replacing "3192" by "3193" The HT-SC75 is also Macrovision Free!!!"
