Question Panasonic SA-BT735 blu-ray player broken
Discussion in 'Home Cinema Buying & Building' started by Razor88, Jan 28, 2018.
Tags:
  1. Razor88
    Razor88
    May 1, 2017
    England
    My home theatre unit has broken so I need to replace it. Thing is I'm finding it difficult to find a replacement. It needs to have the same 5.1 surround sound connectors and optical audio in. Bit tricky finding just a unit. Any suggestions? Perhaps I'm searching for the wrong thing?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,862
    The Borders
    +3,558
    Is your ‘system’ the SC-BT375?
    What has broken and what are you looking to replace?
    Joe
  3. Razor88
    Razor88
    May 1, 2017
    England
    The main blu ray player unit. The code flashing up on the box suggests it's the power supply that's at fault. However we took it to a local home appliances electrician who looked at it but couldn't fix it. So we now have all the speakers but struggling to suitable replacement unit that'll work with the Panasonic speakers.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,862
    The Borders
    +3,558
    Most ‘all-in-one’ systems include Speakers in the package which means either swapping the Speakers out or ending up with a new boxed set of ‘spare’ speakers.
    Joe
