Panasonic S75 - Zoom question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Andrew_arkless, Oct 13, 2003.
  1. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    I'm considering the Panasonic S75 but have a question on the zoom feature. Does this feature zoom the picture so that say a 2.35:1 film will fill a normall widescreen TV ? i.e. remove the balck bars top/bottom. If so is this while the DVD is playing or is it limited to freeze frame.
    Thanks for your help!
  2. Captain chaos
    Captain chaos
    Why would you ever want to zoom a 2:35.1 image to fill the screen?
