Panasonic S35 and DVD-RAM Cartridges
Discussion in 'Blu-ray & DVD Players & Recorders' started by DaveP, Jul 14, 2003.
  1. DaveP
    DaveP
    Can someone tell me if I can play these in the S35 or do I need the no cartridge variety?
    thanks
    DaveP
  2. mentsugi
    mentsugi
    Oct 2, 2002
    390
    28
    +29
    You need the no cartridge variety. The disc tray is shaped such that only a bare disc will fit.
    Cheap , caddyless disks , are available at SVP and are reliable (I have been using the Mirror RAM for months now without issues).
  3. kyle reece
    kyle reece
    you can remove discs from the caddy if you want .
    there is a push out near the red protect slider
    push it out with a pen you can then open the back of the caddy & slide out the disc .you can then put new discs in the caddy to save from finger prints/scratches .
  4. DaveP
    DaveP
    Thanks guys that's a shame. I've got a few of the caddyless ones and I'm struggling to keep the disks clean.
    I suppose the S75 is the same mechanism?
    Cheers anyway
    DaveP
  5. mentsugi
    mentsugi
    Oct 2, 2002
    390
    28
    +29
    I have got to agree with you that it is a shame. Panasonic stress the importance of the caddy use in the recording but do not support the caddy approach on their latest players???
  6. mike5
    mike5
    Have Panasonic got a player out that will play the DVD rams that are in a caddy. I was going to buy the Panasonic DVD S75EBS so I could do some editing with my Panasonic E50, I wont bother if it does not play the discs in the caddy. Ive got a load of TDK double sided ram discs I would like to transfer to dvdr.
  7. aaronjon
    aaronjon
    ALL optical discs (NOT JUST FOR PANASONIC) should be treated with care, ie, dust free, finger print free, etc. putting them in caddies is one way, but expensive. probably a minimum of 4x more.
  8. chubben
    chubben
    The panasonic s75 only playes dvd-ram without caddy...
