Panasonic S35 and Bang Olufsen
Discussion in 'Blu-ray & DVD Players & Recorders' started by barnetda, Apr 13, 2005.
  1. barnetda
    barnetda
    hi
    I have a Panasonic dvd S35 . Works fine with my portable tv. I cannot get it to work with my B and O TV. I get the dvd initial picture but as the film loads the tv switches back to TV programmes.
    Any ideas . Other DVD players seem to work fine with my B and O.
    thanks
  2. barnetda
    barnetda
    I would really appreciate any ideas. Do you think its just not compatible?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you need to set B&O TV AV input to something, dependoing on the model depends on the options available to you but setting it to decoder or AV often works
  4. barnetda
    barnetda
    Thanks for the idea hornydragon. That didnt work i tried every combination.
    Its weird. It can see the dvd (the dvd start page comes on) but as soon as the disc begins to play it switches back to the tv channel.
    Any other ideas greatly appreciated.
  5. Chris Nicholl
    Chris Nicholl
    Apr 14, 2005
    241
    28
    Tunbridge Wells
    +44
    What B&O television have you got and how are you connecting the two together?
  6. barnetda
    barnetda
    i have a B and O MX 6000.
    I am connecting them with a scart lead directly to B and O av 2.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    what have you set DVD player output as? try Composite and set AV2 to decoder then press corresponding remote button to select AV2
  8. barnetda
    barnetda
    sorry Hornydragon, but where do i set the dvd player output. ive looked in setup on the S35 but cant find it.
    i have changed the b and o to decoder.
    sorry to be a pain.
  9. barnetda
    barnetda
    on the video out tab on the panasonic i have 3 choices.
    1. video Y pb pr
    2. s vIDEO y pb pr
    3. rgb/ NO OUT PUT.
  10. Chris Nicholl
    Chris Nicholl
    Apr 14, 2005
    241
    28
    Tunbridge Wells
    +44
    Option 1 from the DVD player - video Y pb pr.
    This should send a normal composite signal up the scart to the B&O.
    Option 3 would be preferable but I'm not so sure the MX6000 will accept a RGB signal
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    AV2 on Mx6000 is S-video/composite IIRC AV1 is RGB, if you have a B&O VCR in AV1 move it to AV 2 and have DVD on AVi RGB (sorry a bit rusty on MX6000 sets.....) also a quick call to local dealer should sort it all out....i thik it was LX TV's but some old B&O have 2 scarts but only one input on the chassis AV2 was an optional extra.......either call your local dealer of B&O technical in gloucester
  12. barnetda
    barnetda
    Hormydragon.
    You are a star.
    That sorted it. I switched the scars around and she works fine.
    Many thanks for that.
