Panasonic S27 & DVD -RW
Discussion in 'Blu-ray & DVD Players & Recorders' started by Colin 28, Jan 28, 2005.
  1. Colin 28
    Colin 28
    Jan 18, 2005
    49
    Can anyone advise if the Panny S27 will play -RW. Would be using it as secondary player for recordings made on Tosh XS32.
  2. micke
    micke
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,217
    Argyll
    +2,267
    The S27 certainly CAN play DVD-RW discs! Although if you use DVD-RAM with it and the Toshiba then there will be no need to finalise/unfinalise your recordings!
  4. Colin 28
    Colin 28
    Jan 18, 2005
    49
    Thanks both for info and advice. Much appreciated.
