Panasonic RV41 + Techtronics Multimod
Discussion in 'Blu-ray & DVD Players & Recorders' started by andybrice, Jan 12, 2005.
  1. andybrice
    andybrice
    I have a Panasonic RV41 with the Techtronics Enterprise Multimod fitted. This was done a few years back and I have lost the manual.
    Does anyone know how to change regions on this player with this mod as Techtronics are out of business and their website is no more?
    I think it is a combination of keys when the unit is in standby but can't remember which... :confused:
  2. LoosyLou
    LoosyLou
    I have a panasonic RV60 from them so I don't know if the mod is the same but to change mine...
    Put the unit in standby.
    Press 0 8 Enter
    The zero enables the autoswitching of regions and the 8 is for PAL tv.
    To switch to a specific region you just replace the 0 with the region code.
    Replace the 8 with a 9 for NTSC.
    Hope it works for you
  3. andybrice
    andybrice
    I think it will be similar because I fitted the mod myself and from memory the instructions were for the RV31, RV41 and RV62.
    Hopefully all these models share the same or similar MPEG decoder so the chip may be the same.
    I'll give it a go and post the result.
    EDIT: Just tried it and can't get it to change region. I have checked using the service code by pressing pause and eject on the front panel with 6 on the remote. The first digit on the left displays the region and remains on 2 whatever I do.
    When entering the codes do you press the buttons in sequence or all at once? I seem to remember it was a case of hitting some buttons simultaneously...???
  4. Razor
    Razor
    Dec 15, 2004
    37,615
    2
    +12,442
    I cant beleive techtronics are out of business. I found they were really good. Amazing chips.
    Big shame.
  5. andybrice
    andybrice
