Panasonic Region Hack
John AT
Could anyone tell me whether there is a region free hack for Dvd and Blu Ray for a Panasonic DP UB820 player. Many Thanks
neuty
DVD will work with the remote above. For Bluray multi region it will require a mod chip.
neuty
THX2002
Thanks, but seems pricey, considering the chips were going for about 40 Euros to DIY before I lost the link...
Ive gone down the regionfreedom route.
neuty
THX2002
Rattlebytes is a hard-wired chip and I believe modified firmware, regionfreedom is modified firmware only, with a couple of extra features as explained on the site. Pricing is about the same, but it seems regionfreedom is very picky who he sells the firmware to. Google will be your friend to read reports around the net.
Pickle2503
Does anyone sell custom firmware that lets you have all audio codecs on mkv files? Or should just go ahead and buy an nvidia shield at this point
scififan
I have the DP-UB820 blu-ray player, I'm strongly considering the RegionFreedom route. Have you had any issues with the firmware update on yours at all to date?
THX2002
I have not even had a chance to watch a single movie, so cannot comment, but I've certainly never read comments online about it causing any issues.
Good luck trying to get it, you do have to jump through a few hoops before he deems you are worthy ;-)
regular_guy28
I’ve just went through this, took a bit of time to get there but up and running now and works great. Would thoroughly recommend to anyone.
