Panasonic Ram Dvd Won't Play On Pc
Discussion in 'Blu-ray & DVD Players & Recorders' started by GASJKH2, Jan 6, 2005.
  1. GASJKH2
    GASJKH2
    This forum has been my saviour for choosing a DVD Home Cinema system - ent for SCHT37R & very pleased with performance.
    After learning how to use new Panasonis E85 machine over Xmas (great machine), when I load Panny DVD-RAM disc on my PC, the disc is not compatible with ROM drive. The DVD ROM drive is capable of reading DVD-RAM though according to Nero Info Tool (the ROM drive is a Mat****a SR-8585). I would like to be able to edit on my PC if possible.
    Does anyone know why the ROM drive does not recognise these discs, I have also tried Ritek RAM discs and same error message occurs. Appears to be a problem with RAM discs in ROM? It reads DVD- fine though.
    RAM discs are able to be recorded over many times, so would prefer to use RAM discs if possible.
    Is this firmware / coded problem, or what else?
    :lease:
    HELP PLEASE!!
  2. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    I have problems using DVD_Ram because Nero sets them to protected. If I find my notes on how to enable the DVD-Ram I'll post them to this thread. Otherwise do a google for Nero and DVD-Ram.
    Once I got round the problem I can read the video files, copy them and burn to dvd-r etc.
  3. Kabelnet
    Kabelnet
    SR-8585 is a "2.6Gbyte DVD-RAM reader". Probably you used a 4.7Gbyte DVD-RAM in your E85. The two DVD-RAM is not compatible with each other. You have to buy a 4.7Gbyte compatible DVD-RAM reader into your PC to process the records of E85 - I think.
  4. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    In addition, you may need a device driver to be able to read DVD-RAM on a PC. I have always had to install one for any version of Windows. Some OEM drives do not come with drivers/utils whereas most retail versions come with software that includes various utils as well as the DVDRAM drivers.
  5. GASJKH2
    GASJKH2
    Thanks Kabelnet for your help, it was a 4.7GB disc - hence no use, so does anyone know of a proven Panasonic DVD RAM ROM drive/burner which will read ram discs, so that I can edit etc on my PC.
  6. jryoung
    jryoung
    Aug 8, 2000
    35
    Guildford,Surrey,UK
    the 2.6GB size is quite old. Any newish Panasonic RAM drive will be compatible. I have the 3x speed version on my PC, and actually use Linux too, but also had success with Windows reading/writing to 4.7GB RAM. Also, Hitachi DVDROM drives typically will read a 4.7GB ram disc and play the video
    Jonathan
  7. volvofl10
    volvofl10
    Jun 17, 2004
    79
    you do need RAM drivers for a pc, the lg4120b is proven for reading 4.7 single discs
    it wont do panasonics caddied discs, but i take them out and put the actual disc in no problems.
    also, get the £1.50 blank RAM discs, there as good if not better than Panasonics own brand discs
  8. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    What is the message you get when reading the 4.7gb dvd-ram?
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    For £53 you can get the LG GSA4160B from Ebuyer which will handle all the formats including dual-layer DVD. It's Quickfind code 75724.
  10. jirob
    jirob
    If you get a 4160, don't bank on being able to read DVD-Rs! Still not working...
  11. GASJKH2
    GASJKH2
    Thanks guys, have read the reviews and agreed with Nick and gone for an LG GSA4160B from Ebuyer.
    Does everything I need and very versatile ref DVD RAM discs.
    Thanks everyone for your help.
    :thumbsup:
