Panasonic RAM discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bjay, Jan 1, 2005.
  1. Bjay
    Bjay
    I am still having problems recording to my DMR 100 some jpegs via my LG super multi format burner. Whenever I try to add something it tells me my disc is not empty do I want to overwrite it. When I look at the disc which is empty all it shows is a DVD_RTAV folder which I thought may contain the formatting info. Any ideas please.
  2. Bjay
    Bjay
    :eek: Ooops sorry people I realise you have already given me the answer to this one, you can't burn jpegs to DVDs. I get confused doncha know!!! I will now attempt to burn an mpeg and see if that works O.K.
  3. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    Yes you can. I copy JPEGs to DVD-RAM all the time for displaying in my Panasonic HS2. Sounds like your having read/write problems with your DVD-RAM drive.
