Panasonic RA82 or Pioneer 656A?
Discussion in 'Blu-ray & DVD Players & Recorders' started by BeadleMachine, Mar 25, 2003.
  1. BeadleMachine
    BeadleMachine
    Mar 20, 2003
    47
    Hello all,
    am trying to decide which DVD player to buy and could use some advice:
    Currently I have a pioneer dv550 hooked up to a Panasonic TX281 widescreen TV.
    Like many other people here, i experience the dreaded flicker problem when watching R1 DVD's through RGB scart. These are connected to my Pioneer VSX 811 receiver for Surround sound.
    Having tried changing the TV DVCO settings through the service menu I have decided to look for another player. I think i have 3 options open to me:
    1) Buy and S-Video lead to replace my RGB scart cable?
    what are people's experiences with S-video compared to RGB?
    2) Buy the Panasonic Ra82
    available for £170 from techtronics, plays DVD-A and has a 54-bit Video converter.
    Doesn't play SACD
    3) Get the Pioneer DV656A
    plays EVERYTHING, £300
    BUT
    ??? Will I still get the dreaded flicker problem on my Panasonic TV??? :rolleyes: :confused:
    Any sugestions / advice / previous experiences would be greatly appreciated.
    Thanks,
    BeadleMachine
  2. bobbles
    bobbles
    one thing about the Panny one is that it also plays -RAM discs so if you were thinking of getting a dvdr at some point in the near future it would be useful
  3. wakko
    wakko
    I've got the Panasonic TX28 hooked up to the DV656A via a Monster Scart .....result is superb, no flicker, just crystal clear pics.
    Hope this helps,
    Graham
    My Kit : Panasonic TX28PL1, Denon 3802, Arcam CD72T, Pioneer DV656A, X-Box, Panasonic Digibox, Project Debut II Turntable,Monitor Audio Silver 6i(x2), Monitor Audio Silver SLCR, Monitor Audio Silver Sfx(x2), Mission 7C1(Rear Centre)Van Den Huul, Ixos, Chord Interconnects, Monster Scarts, QED Silver Ann Bi Wire, Pronto
  4. nathan_silly
    nathan_silly
    My panasonic TV also had NTSC flicker- no flicker in PAL though.
    I had various NTSC sources- S-video from my R1 DVD player, and RGB SCART from my PSX, NTSC US games- everything with NTSC flickered.
    A couple of guys on this forum mentioned the Panny's do flicker with NTSC material.
    It's not the DVD player at fault.
    Replaced the TV with a Toshiba, no flicker.
  5. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    No flicker with my RA82 and TX32PF10 using RGB.........
    Well happy with the 82, apart from it shows fingerprints badly!
