panasonic question
Discussion in 'Panasonic TVs Forum' started by d3ll, Jan 26, 2005.
  1. d3ll
    d3ll
    Jan 16, 2005
    273
    16
  2. d3ll
    d3ll
    Jan 16, 2005
    273
    16
    link not working, mean this one pictured below
  3. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I didn't think that TiVo boxes could output YUV via their SCART sockets...does it mention this in the manual or onscreen menus...so I would say no it won't work.
    Cheers, Lee
  4. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
  5. d3ll
    d3ll
    Jan 16, 2005
    273
    16
  6. happyhiker
    happyhiker
    Jan 3, 2005
    421
    +26
    I have a TiVo that outputs RGB to a JS RGB > VGA converter and it looks great on a PW6. You will need a JS RGB> Component converter to make it work on component, the lead won't do it by itself.
    You also need to make sure TiVo is set to output PAL and RGB not just PAL Only. (silly me, I've been running on PAL only for 2 years, until I plugged in the JS box and it didn't work and I had to change the settings).
    You'll also have to bump up the picture quality to record everything on high quality, the plasmas real show up the low res pixelation more than a crt.
  7. d3ll
    d3ll
    Jan 16, 2005
    273
    16
    thanks for that happyhiker, very helpful and some good points there.
