J
Jimmathie
Please could you help me?
I live in the UK and was thinking of buying a Panasonic Q from Lik-Sang. The trouble is that as yet it doesnt play UK games!! So I am going to wait a bit longer to see if they come up with a mod to fix this. My problem really is is that if I was to buy one I would have a DVD player and a Gamecube rolled into one. The advantage of this is that the DVD part has Macrovision switched off which is one of the main attractions. In your opinion would it be wise to wait and buy a Panasonic Q (I am scared that if I but it one day the Gamecube part of the unit will be old when another generation of consoles gets released and I am still using the DVD part of it?) or would you buy a Gamecube and then a seperate DVD player? Also, do you know if it is possible to buy a DVD player with the Macrovision switched off as this was a big advantage to the Q?
Sorry to go on but I would just like some advice!
Cheers,
Cheers,
