Panasonic Q
Discussion in 'General Video Gaming Chat' started by shez316, Mar 4, 2002.
  1. shez316
    shez316
    Feb 25, 2002
    117
    +3
    I was thinking of getting this from Lik Sang. Do any of you guyz have it? Is there a way to convert it to PAL? What is the DVD playback like? Do I just plug it in or do I need some other equipment, such as transformers? What do you think of it?
  2. stewarthollyhead
    stewarthollyhead
    Adapter: you get this from Lik-sang free automatically
    Connectin: I believe you get the cable but you can ask this to lik-sang they willreply and add whatever is needed to your order.
    Playback Quality: havent heard anything about it. But panasonic are respectable so shouldnt be shabby.
    Invoice: ask them and they will alter your invoice to 50% of the price. This will mean you wont get shafted so much on custom tax
  3. museumsteve
    museumsteve
    Jan 28, 2001
    7,959
    4
    Nth Hampshire
    +1,088
    playback is great..up there with the best panasonics..
    supports component out but you need to buy a specialist cable..
    It can't be converted for PAL at all, but can be multi-regioned through firmware for Reg 1..
    looks funky..
