Panasonic Q S-video connection
Discussion in 'General Video Gaming Chat' started by mpthink, Aug 8, 2002.
  1. mpthink
    mpthink
    Hi there I have a problem connecting my Panasonic Gamecube Q using its s-video port.
    Although I live in the UK, my TV is NTSC compatible and works fine with the AV cables. But when I try using s-video I get a slightly fuzzy black and white picture. Do I need to buy a Japan-specific cable to make it work, or am I fighting a losing battle?
    Anyone who can help please let me know!
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,365
    Norwich
    +892
    my mate has a sony 36" and he had to go into the service menu and turn ntsc s-video detection.
    maybe the same thing.
    just thought another friend has the same thing with a panasonic , not sure which model it is but it has a black case.
    what model tv you using ??
  3. mpthink
    mpthink
    Tried changing the menu to S-video on and it's worked like a treat. I now have a really nice, sharp S-video resolution.
    The tele is a Toshiba (not sure the model number) and weirdly the s-video socket is scart-shaped - you can toggle scart and s-video on the menu.
    Anyway thanks :)
