Panasonic PWD7 & Input Boards
Discussion in 'Plasma TVs' started by BlueNote 39, Aug 1, 2005.
  1. BlueNote 39
    BlueNote 39
    Dec 18, 2003
    279
    South Central Brum
    +10
    I have a PWD7 which I have set up with 2 additional input boards the component/composite/SVHS dual board which I have put into slots 1&2 and the scart board which I have in slot 3, My Sky box is connected to the scart board however I cannot get a picture on the panel I have tried selecting all the inputs. The DVD which is connected to the component baord works fine.
    Any ideas/help would be greatly appreciated.....does the scart have to be connected in slot 1 or 2?
  2. Dave
    Dave
    Jul 3, 2005
    11,483
    163
    +3,392
    Yes. I believe the third input is not rgb compatible so you'll have to put it in one or two.
  3. gunizzle
    gunizzle
    the the scart should ideally be in slot 1, if youve got the dual input board then put that into slots 2 and 3, it should work fine then. I think the scart only works in slot 1 or 2. Thats what ive been told anyway!
  4. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    also..the scart has two states...rgb and composite and you need to press input twice to switch between them......so it may work in slot 3 if you try that...otherwise as has been said above the dual slot works just foine in slots 2 and 3. Also make sure sky is set to rgb and not PAL in teh picture settings.
  5. BlueNote 39
    BlueNote 39
    Dec 18, 2003
    279
    South Central Brum
    +10
    Guys,
    Thanks for your help on this one .I'll change the boards over and this as stated should resolve ....
    Gurdip
