Just after some advice regarding this as I'm not that great or up to speed on the technical side of things! I bought one of these a while back and it came with the Panasonic speakers that attach to each side of the screen which has been fine up till now.
The problem I have now is that I need to relocate the plasma and the area I want to move it to isn't quite wide enough to take the panel with the speakers attached but it is wide enough to take the panel alone minus the speakers.
So I'm wondering what alternatives I have if I was to remove the speakers. I have a Denon UD-M31 cd receiver nearby and was wondering if it was possible to connect the panel to that in any way so that the tv sound would then come from the Denon's speakers? But as mentioned I really don't know if that's viable or a complete no go!
Any thoughts will be appreciated! Thanks in advance...!
Dan.
Dan.
