Panasonic PWD6 which terminal board?
Discussion in 'Panasonic TVs Forum' started by Shahel, Oct 22, 2004.
  1. Shahel
    Shahel
    hi there all just started on this board been watching for a week or two. i have had my pwd6 for about 2-3 months now been using it with a pioneer c501 but need something more powerfull and tweekable so just ordered a Denon 3805. the terminal boards i have are scart and bnc componet boards TY-42TM6A the amp has RCA componet out can i get some sort of adaptor from rca to bnc or should i buy a RCA componet board?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Just buy a 3 RCA to 3 BNC cable in the length you need see the mark grant powerbuy.....custom cables with whatever ends you need. Made from top quality cable and crimped using top notch tooling.....
  3. Digger
    Digger
    Dec 31, 2003
    4,385
    World Wide Supermarket
    +205
  4. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    I also have the Denon 3805 and the bnc component board on my PWD6. All you need is an rca to bnc component cable, or you can even get rca to bnc converters.
    I route my DVD, vcr and xbox via the amp and it works very well.
  5. Shahel
    Shahel
    thx for the help guys :D
    btw do you think i would get anything for the scart terminal board as i guess i wont be needing ot anymore or should hang on to it?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i would either hang on it can be useful for connecting the odd bit off kit. OR sell it you will get a few ££££ on Ebay from some muppet!
