panasonic pw7 picture prob
Discussion in 'Panasonic TVs Forum' started by Baron Von Doom, Aug 26, 2005.
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    i've noticed when watching dvd that on shots that pan across the screen the picture seems to stutter. this happens when the picture is moving across the screen or from bottom to top. every about half a second the picture will sort of stutter for a split second.
    The dvd player is a toshiba sd530e and does it connected with component or scart. has anyone heard of this before? is it more likely to be the screen or dvd?
  2. Dave
    Dave
    Jul 3, 2005
    11,497
    163
    +3,401
    I may be wrong but I think it has something to do with the frame rate conversion. As I understand it, the screen runs at 60 hz where the DVD runs at 50 hz. The screen therefore repeats some of the images in order to make it 60 hz.
    This is what causes it to look like it's stuttering. I have absolutely no idea how to fix it but I'm sure someone else can help in this department.
  3. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,607
    Aberdeenshire
    +181
    This stuttering happened when my son connected his XBox to the PW7. We were able to cure it by going into the XBox set-up menu and changing the frame rate it was outputting.
    I've not seen it on any other source though. Does your DVD have a menu somewhere, that you can change the frame rate?
  4. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    no doesnt have anything in the menu to do this. i dont know of any player that does
  5. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    458
    +3
    have you tried it with region 1 discs , i presume they would run ok
  6. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    ive not tried region 1 but pretty sure it done it on my jap kung fu hustle superbit which is ntsc
  7. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    458
    +3
    hmm i thought NTSC discs would run at 60hz curing the problem ?? ive just bought myself a PWD7 and a HD950 HDMI dvd player i hope i dont have the same prob :(
  8. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Have you got you dvd player set to NTSC or 60Hz?
    the PW7 is one of the few screens that can display 50hz at 50Hz so it is not the screen, it must be the source.
  9. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    there doesnt seem to be any settings for this on player
  10. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Not a switch on the back?
  11. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    theres a switch for scart or component
  12. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Can you put a tv signal into it and see what happens?
    Also what happens when you put it in progressive mode?
  13. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    just been trying sky through it and have couldnt see it doing it. will try progresive later.
  14. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Try the ticker tape running along the bottom of the news channels to make sure.
  15. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    still does it in progressive mode. cant notice it on the news channels. not sure if it would do it on a whole screen panning across but if it does ive not really noticed it.
    very noticable on dvd though
  16. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    does anyone think a new dvd player will solve this?
    if so any suggestions pref under £150
  17. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    458
    +3
    dont know if it will solve the problem but richer sounds are doing a nice one a DVD HD950 Samsung with HDMI input £129.99 muti region
  18. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Also www.play.com are doing the Philips 963 for £120, great player with component output and probably the best if you want to SDI mod at a lter date.
  19. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    458
    +3
    been checking out that HD950 through RGB scart today , its dosnt even come close to the quality of my SD220 Toshiba .. hope it preforms better on the HDMI output when i have my plasma set up
  20. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    I don't like it at all, my mate bought one and was raving about it, I thought it looked terrible on any output. But then it does do everything including making the dinner for just over £100, so to expect it to have a good image as well is maybe asking a little too much! :)
  21. av2diefor
    av2diefor
    Put me down for the 950 if it makes dinner as i think my wife is about to leave me for spending too much time on here :)
  22. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    458
    +3
    hmm well i think ill buy a van den hul HDMI lead for it and i was also thinking of picking up a Black widow power block so hopefully this will make it look a bit better
    but i do like the black look :clap:
  23. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    :D haha excellent!
  24. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    458
    +3
    well i was thinking of using my Power block for the screen and amp too
  25. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Oh, sorry, I thought you were joking! :suicide:
    Why spend all that money on a cable and power block? That is £170 in total!
    Get a better player first.
    You would get far, far better results by spending £300 on a player.
  26. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    My wife keeps making those promises too, but she is still there every night when I get home! :thumbsdow
    I wouldn't know what to do without her really! :)
  27. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    458
    +3
    :( :( ha ha na im new to this :oops: , are those power blocks any good tho , what ive been reading suggest that it will improve my plasma , my sounds and my DVD
    also giz you know anyone with some mission M71i or M71 in black for sale
    sorry to go off topic :rolleyes:
  28. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    I get as nerdy as the next person when it comes to cables etc. but I have never used anything special for a digital connection, unless you have serious problems I just don't think they will make any difference.
    I am looking for a power conditioner for my kit at the moment, but trying to find a decent used one. I just think that should all come after you get the kit spot on.
    Don't know anyone with any missions for sale mate, but will keep an eye out for you.
  29. Goofy
    Goofy
    Jan 10, 2005
    97
    Leeds
    COOMBES123 - You might want to try and ring Superfi in Leeds - last time I looked, they had a Marantz DV4500 for £99 (half price) - a good machine.
    Your problem is definitely down to the player. I have been using a Denon 2200 with my PWD7 and it gives great pictures, no stutters, layer-change problems or any of the other issues which are mentioned on this forum from time to time.
    Using the "progressive" mode on any of the cheaper players is probably a pointless exercise - the PWD's electronics/software will be far better at de-interlacing.
  30. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    thanks. will check the marantz out.
    i agree about the progresive scan. there was never any difference in pic quality with it on or off
