panasonic PW7 installation question
Discussion in 'Panasonic TVs Forum' started by Jaye, Apr 11, 2005.
  1. Jaye
    Jaye
    I have just had my panasonic PW7 delivered & installed.
    I've noticed that there are several "bands" running across the screen, made up of a number of vertical lines. Can someone tell me what the problem is please.
    Also when I put tht DVD player on, I only get the sound, not the picture from the DVD.
    I would really appreciate a bit of advice from anyone!!!
  2. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    638
    +7
    Looks like you're at the stage I was at a couple of days ago with my PW7 (but you did ask for anyone's advice ;)). I also had lines on my screen (horizontal though) and they turned out to be intereference from mains cables (behind the wall) getting into my scart cable from DVD to PW7. Just check that your cables are anywhere near mains cables. Also add the ferrite beads to them if you haven't used them elsewhere.
    As for the lack of picture from your DVD player, not sure. How do you have it all connected (video and audio)?
  3. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    Jaye - you need to tell us how the devices are connected, what type of input card etc.
    Media Box, Component Card, VGA input / JS etc etc / Scart
  4. Mep
    Mep
    Dec 25, 2004
    9,610
    Surrey
    +477
    and your sound set up....is the dvd connected to an amp?
  5. Supersonic72
    Supersonic72
    Jan 10, 2005
    245
    There ferrite cores....
    I got a couple of the large ones with the screen, but havnt used them, as I thought they were for PC/VGA cables...
    Can I used them on the scart cable then???
  6. Mep
    Mep
    Dec 25, 2004
    9,610
    Surrey
    +477
    i use them on everything...i got loads with the screen and figured even if they dont help...they can't hurt it
