Panasonic PW7 help
Discussion in 'Panasonic TVs Forum' started by oanyego, Apr 21, 2005.
  1. oanyego
    oanyego
    Apr 21, 2005
    Ive just installed the Panasonic PW7 withTUPT600 media box, everything is great except I have a couple of queries.
    1. Is is ok to watch widescreen 16:9 format in the first 200 hours or at all?
    The handbook says not to watch 4:3 for an extended period but I am concerned about the horizontal black bands above and below picture image in 16:9 widescreen format cause after image/burn in.
    2. I want to set up screensaver/wobble on and energy saving settings from the set up menu, however (i may be being really dumb here) I cannot find a way to select 2nd page of this menu where these settings are (i only know this from image in handobook). I only get first page of set up options.
    Can anyone help?
  2. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    yes mate leave it in 16:9 and select cinema mode and enjoy,
    If you turn the media box off your be able to enter the menus using the plasma remote and switch the screen saver options on.
    Once this is done sit back and enjoy.
    Dal
  3. oanyego
    oanyego
    Apr 21, 2005
    thanks :smashin:
    i
  4. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    No problem fella.
    you dont state what your connecting to it.
    If u have Sky or similar make sure thats plugged into AV1 or AV4 and set your sky box or similar to output RGB.
    Same for your DVD player if it uses RGB scart.
    Dal
  5. Jpfahy
    Jpfahy
    Is there a screen saver???
    I thought once the tuner was connected it overrides everything to do with the plasma remote
  6. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    whether is does or not i have switched the screen saver on and the wobbling or whatever its called.
    To be honest when i first got my PW7 i was really concerend about screen burn. but 2 months on i never think about it now. Unless you have the brightness and contrast up full and leave it on the same channel for hours on end i doubt your have a problem.
    Dal
  7. Jpfahy
    Jpfahy
    Does that mean you can have the screensaver with the tuner connected?
  8. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    the screen saver has never come on as its always got a signal coming through it.
    If for some reason my mediabox switched itself off then my screen will automatically go into powersave standby.
    Dal
  9. pioneerman
    pioneerman
    Mar 25, 2004
    2,530
    71
    surrey
    +63
    i have had mine connected via media box for about a month now i did not know that if i turned off the media box i could access the plasmas set up thanks for that w3dal. i have read other threads saying that with the media box you could not do this. :thumbsup:
  10. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    no problem fella.
    Dal
