Pugs1
Can anyone recommend the best way to setup my PW7?
Ive just bought a PW7 and installed both a component (BNC) board and a scart board (will input RGB/S-Video).
I want the best possible connection between my Denon 550SD home theatre amp/DVD, sky digital box and Plasma.
At the moment the Sky box is connected to the Denon amp via scart/s-video lead and out through the amp via S-Video (the amp does not have RGB Scart). The DVD is connected via the amp and in to the Plasma via component cables. The amp also has a second lot of component outputs which are not used.
So given the fact that I have
1: One component board (plasma)
2: One scart board (plasma)
3: VGA In (plasma)
4: Two component outputs (amp), one connecting DVD and going to Plasma.
5: S-video and Scart (Sky box)
6: No scart, only S-Video/Component/Composite (amp)
So what would be the best way of setting up the system?
1: Do I buy some sort of converter (js converter/which type) etc?
2: Do I buy another board for the Plasma, if so which one?
Only other thing is the amp menus will only appear on the Plasma screen if I use S-Video!
Any ideas would be really appreciated.
3: VGA In (plasma)
