Panasonic PW6
Discussion in 'Plasma TVs' started by philp_i, Aug 3, 2005.
  1. philp_i
    philp_i
    Aug 1, 2005
    92
    I have a panasonic PW6 plasma with a scart and component board, i have always been very happy with the picture even though i have never used component, im about to swap this plasma with a m8 who wont be happy unless he is getting the best possible picture from it.
    So what im asking is they any way to get a better picture watching SKY and dvds? or any thing else you can buy?
    Would changing to sky+ give you any better options? whats the best possibe picture you have on the panasonic pw6.
    Many thanks
  2. stevelup
    stevelup
    Aug 13, 2002
    6,125
    Swindon
    +838
    You can achieve better picture quality than the SCART board by using the VGA input.
    To do this, you will need some kind of sync separator such as a Keene Syncblaster cable or the highly (over)evangelised JS Technology RGB>VGA converter.
    If you go this route, you will lose auto widescreen switching which will require shelling out another £100 to fix.
    I would say though that if your mate is 'normal' - in other words, not the kind of person who frequents these forums, he will probably be absolutely fine with the SCART board!
    Sky+ adds an S-video output, and Dolby Digital capabilities. Neither of which will impact on the picture quality of your panel.
    Regards,
    Steve
  3. Parklife
    Parklife
    Jun 9, 2004
    557
    28
    +33
    For Sky get a JS Tech RGB to VGA converter. This will then plug directly into the VGA input on the back. Great improvement over the scart board.
    DVD via component would also give a better pic than scart.
    For the ultimate get is professionally calibrated. If you could not stretch to that a DVE disk should improve the picture quality.
  4. philp_i
    philp_i
    Aug 1, 2005
    92
    Hi After reading various threads on this forum last night im amazed at different options available on this screen.
    Could someone please tell me where i could get a JS Tech RGB to VGA converter? am i right in thinking this will only work with a sky box with RBG?
    Also m8 could you explain in a bit more detail to what this involves as im still a beginer
    Many thnaks for your help.
  5. philp_i
    philp_i
    Aug 1, 2005
    92
    I have just noticed that i have a composite board instead of a componenet so i now need a component board, i phoned the shop where i bought the plasma from but they dont sell them, does anyone know where i can get a component terminal board from?
    Also is my composite one worth anything?
    Last thing where do you buy a DVE disk from?
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
  7. philp_i
    philp_i
    Aug 1, 2005
    92
    Im swapping so i can get the best possibe picture from my plasma, how does this converter work?whats the scrat input on the inverter for?
  8. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    i think he meant what screen are you swapping it for mate!...look at the js web site it explains everything for you...Giz gave the link above
  9. philp_i
    philp_i
    Aug 1, 2005
    92
    lol sorry. Is this the converter i need for my sky+ box? Im reading website now so hopefully the stupid question will stop sometime soon.
  10. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    you go sky+->rgb scart->RGB to Component (YUV) Video Converter->3phono to vga cable->vga input on PW6.
    Tell your plasma that the vga input has component coming in rather than RGB.
  11. philp_i
    philp_i
    Aug 1, 2005
    92
    What advantage would this rgb-Component converter to me over the VGA to plasma converter from the same place?
  12. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    To quote myself from a post just above :D
  13. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    And what are you swapping for?
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    but there are advantages to each the RGBcvS to YUV transcoder is a more complex process than the RGBcvS to RGBHV (actaully RGBS) conversion which just cleans up the sync and doesnt touch the Red green Blue colour info the only need for colour control is to correct issues with the source equipment which can be done with calibration of the screen.............
  15. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    Very true, the VGA transcoder was definitly slightly better than the YUV one, but if you don't want to go in the service menu the YUV may be a better bet.
    I still want to know what screen he is going for? :)
