Panasonic PW6 & Wattgate 320 IEC
Discussion in 'Plasma TVs' started by loonatic, Aug 27, 2004.
  1. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    I have recently upgraded all of my cables to Russ Andrews, a mixture of YellO and PowerKord.
    I got a PowerKord with a Wattgate 320 IEC connector for the plasma screen but it does not want to fit...nor will any of the other cables with more standard looking IECs fit.
    Has anyone else changed their power cable ?
    Cheers, Lee
  2. Arcangel
    Arcangel
    Yep. Using one of Mark Grant's cables but I had the same problem, the Wattgate wouldn't fit in the Plasma. I cut off the end of the standard power cable and fitted an IEC adaptor to it. :)
