Panasonic PW6 vs. Fujitsu VHA30es
Discussion in 'Panasonic TVs Forum' started by fuji, Sep 13, 2004.
  1. fuji
    fuji
    Jun 10, 2004
    41
    Dear All,
    I'm currently in a dilemma about the silver Panny (the forum favourite) and Fujitsu, question is which one to choose?
    The Fuji has a 2 year warranty and component and scart fitted but costs more than the Panny which is significantly cheaper when boards are fitted, but with 1 year warranty.
    Is the Fuji worth the extra?, and which one gives the best picture quality overall?, I'll be using a freeview box, dvd recorder, satellite (not sky). Hi-def is not a major concern.
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    get a Nationwide Credit card, then buy the Panny with it.
    Nationwide will extend the warrenty by 1 year for nothing.
    The Panny comes with a SCART board usually, and already has a component
    input built into it (VGA connector) you only need to buy the component to VGA lead (£17) and at £1850, it's a good price.
    Fuji & Panny have the same screen, so not much diff. PQ wise.
  3. fuji
    fuji
    Jun 10, 2004
    41
    Thanks for the reply and useful advice, I've already got two credit cards, and dont really want to take out another if it can be helped, plus the time it takes for applying and getting the card. The cheapest SILVER pw6 I've seen is about £2197, with a stand about £2317, How are Pannys for overall reliability compard to Fujitsu's?
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
