Panasonic PW6 VGA or Component Card
Discussion in 'Panasonic TVs Forum' started by bbasra, Jun 16, 2005.
  1. bbasra
    bbasra
    Sep 15, 2004
    1,660
    48
    Hounslow
    +42
    I am going to upgrade my setup to component now and am going to buy the JS technology RGB to YUV converter.
    My plasma only has a scart and vga input, no component card.
    my setup will be as follows:
    Progressive Scan DVD player Component YUV into Denon 3805 YUV Input 1
    SKY+ RGB SCART to RGB SCART into JS Tech Convertor and then JS Tech YUV into Denon 3805 YUV Input 2
    My issue now is:
    Do i buy a new Component Card for plasma slot 2 and connect a YUV cable to YUV to the YUV ouput from the Denon and into this new card?
    OR
    Can i use the VGA input on my plasma and buy a Component (3x Phono) to VGA cable. Basically Connect the 3 x phono to my Denon YUV output and into the VGA into the plasma?
    I know i will get progressive/component with the first solution, however, will it be the same if i use the second option.
    TIA's.
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    as far as i know you can do component to vga on the 6 series.....they nobbled it thereafter.
  3. bbasra
    bbasra
    Sep 15, 2004
    1,660
    48
    Hounslow
    +42
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    looks like it will do the job and you'll need to set the vga input to component on the panny and I don't know which dvd player you have but the panasonic may do a better job of prog scan anyway
  5. bbasra
    bbasra
    Sep 15, 2004
    1,660
    48
    Hounslow
    +42
    I have the Pioneer DVD 575 Player. I just used this cable as an example.
    Do you know where i can get a decent component to vga cable from. i need it to be 5m.
    and how do i change the vga input to component.
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    you could try av-sales (they make up van damme cables and others) or look in the cables section here for Mark Grant who makes cables (not sure if he does vga though). To change your settings just go to teh right input and change it in setup
