S
silron1
- I've had it since 2003 and its used as our main TV & DVD Recorder/Player screen.
Its never let me down & the picture quality is still fantastic. However I need to be able to screen HD-DVDs from my Toshiba HD Player. I can do this through the VGA port using a HDFury convertor but that produces a soft image. The reason is that the Panny max res is too low for the convertor - thus the soft image.
So I want to look at a replacement screen. It must be a Panasonic but I cannot find anything similar to the PW6. I only require the display screen as I have all the boxes, Sky, Freeview, Yamaha Sound System.
I would like to go to a 50" 1080p but where do I find a display screen without built-in receivers & audio etc.
Any suggestions other than the pro display screens circa £3000+ would be much appreciated
