Panasonic PW6 problem
Discussion in 'Plasma TVs' started by geeWcee, Dec 1, 2004.
  1. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    My mate just bought a PW6 and he seems to be having a problem with it.
    He is getting faint diagonal lines running across the picture constantly (both sky and DVD sources - scart and composite)
    To be honest when I went to have a look I didnt really notice it until I was sat a metre from the screen, but it seems to be bugging his girlfriend more than him. So he notices it all the time now.... :rolleyes:
    Is this a known issue with PW6's or a faulty set?
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    You should have the answers for him, you have a PW7! :laugh: :smashin:
  3. stevelup
    stevelup
    Aug 13, 2002
    6,125
    Swindon
    +838
    Sounds like it could be dodgy / cheap SCART leads.
    How is it all wired up?
    Steve
  4. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    Leigh: picture is fine on my PW7, it doesnt exhibit the diagonal line problem, cheeky! ;)
    Steve: I knew he would have cheap nasty interconnects so I took all my top quality cables over and it still made little difference. Sky connected up via scart and DVD thru composite.
  5. stevelup
    stevelup
    Aug 13, 2002
    6,125
    Swindon
    +838
    Hmm
    Most likely cause is an earth loop.
    Is the plasma connected to the same power sockets as the rest of his kit.
    He should try disconnecting everything apart from the video cables - in particular it's worth removing any audio leads temporarliy.
    Steve
  6. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    Yes, he runs everything from the same power outlet...
    I'll let him know and see if trying what you suggest helps. Cheers.
  7. stevelup
    stevelup
    Aug 13, 2002
    6,125
    Swindon
    +838
    The Sky boxes tend to run with quite a "hot" chassis. Often 80 or more volts when measured relative to ground.
    It might be worth grounding the Sky box. To do this, get a reasonably hefty bit of wire and wrap it around the F connector on the back of the Sky box.
    Connect the other end to mains earth.
    Steve
  8. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    Many thanks for your suggestions stevelup, my mate solved his problem today and is well chuffed with his plasma once again ;-)
  9. stevelup
    stevelup
    Aug 13, 2002
    6,125
    Swindon
    +838
    What did the problem turn out to be?
    Steve
  10. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    Turned out to be the sky box. When he takes it out of the system every other source is fine. Plug sky back in and it causes the interference.
    Anyway, he says he got it sorted so once again thanks steve.
  11. spook
    spook
    May 18, 2004
    157
    geeWcee, can you ask your friend how he sorted this problem?
    cheers, Spook
  12. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    Will do spook. I will get back to you on it.
