Panasonic PW6 or PW7 with a PC input
Discussion in 'Panasonic TVs Forum' started by dan23, Jan 7, 2005.
  1. dan23
    dan23
    Oct 31, 2004
    96
    11
    +3
    Plasma n00b here was wondering how well do the Panny's handle an input from a PC and what resolution will they take?
  2. dan23
    dan23
    Oct 31, 2004
    96
    11
    +3
    Anyone?
  3. Rambles
    Rambles
    Jul 14, 2004
    8,125
    UK
    +1,096
    Hi, I have just got a PW7 37" and have my media center PC connected via VGA, it looks stunning. XP detects it as a TH***PW7 monitor and will allow me to select a number of different resolutions, the native resolution looks best 852 x 480 but is only 4:3 so am still experimenting with different settings for surfing, watching films etc.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    it will accept everthing from VGA res up to 1920x1080
  5. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    I am running a PW7 as second monitor to a dlp projector and it is fine with 1280 x 720.
    Ken
  6. dan23
    dan23
    Oct 31, 2004
    96
    11
    +3
    I'm confused, how can it do that res if the native res is 852x480? :confused:
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    because whatever you feed it, it will down scale 720p signals work best......1280x720 or 1366x768 and let panel downscale to native
  8. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    Doing this also makes the desktop more user friendly.
    Ken
  9. Rambles
    Rambles
    Jul 14, 2004
    8,125
    UK
    +1,096
    Just trying this now, in the manual (TH37PW7) it does not accept 1280x 720, the best I have found so far is 1024 x 768, but text is a bit blurry.....
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    what fequency are you using? that will effect what it accepts.... have you tried powerstrip?
  11. Rambles
    Rambles
    Jul 14, 2004
    8,125
    UK
    +1,096
    Hi, thanks for your patience with me!
    My nvidia drivers allow me to input custom resolutions, and I am trying them all with refresh rates from 60, 70, 72, 75 and 85.... trying to find one that works well for surfing and film playback - what settings are you using?
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    dont mess around with PC's to much hassle..... Try the HTPC forum for more info and try 50Hz there are some tricks like usig 1368 instead of 1366 etc
  13. Rambles
    Rambles
    Jul 14, 2004
    8,125
    UK
    +1,096
    OK, thanks... not explored that forum yet :hiya:
  14. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Would using a DVi input help? I want to connect my pc to my PW6 but dont want to have blurred images but I dont want a low res either! Prob want what I cant have I expect! :(
  15. Neelix
    Neelix
    If the native res is 852x480 i.e. VGA akin to 640x480, then you will be able to view your pc just about but icons and such will be so big you won't be able to do much on it. Try browsing the net or running photoshop at 640x480... it's near enough impossible these days as programmmes and websites have been designed to support much higher resolutions normally 1024x768. This is part of the reason for going to a HD panel :)
  16. Rambles
    Rambles
    Jul 14, 2004
    8,125
    UK
    +1,096
