Panasonic PW6 and PW7 serial control
Discussion in 'Panasonic TVs Forum' started by nigels0, Oct 5, 2004.
  1. nigels0
    nigels0
    Sep 7, 2004
    42
    I know this may be a bit arcane, but does anyone know whether the serial control protocol to control the PW7 is teh same as that used in the PW6? Reason is that I want to use a source that controls a PW6 via the serial port (power on, brightness etc), but I want to use this on a PW7.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    will probably be the same or very similar..... MAW/Joe/Gordon will know soon if not already...
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Panasonic haven't changed this in 3 models previous, I very much expect it to be the same. The internals are very similar to the 6 series, best advice now is to try it, asking Panny is not much use, maybe steljes or another of the large distibutors will know for certain.
  4. nigels0
    nigels0
    Sep 7, 2004
    42
    Thanks for the replies. It is tricky to try out as I haven't yet bought the screen - but I'll have to find some way of doing this. Gives me confidence though that they rarely change this.
  5. Treworgey
    Treworgey
    Nov 17, 2004
    Has this question been answered for definate? i.e. if the 7 is the same as the 6, chances are the 8 will be the same too - right?
    Additionally does anyone know if the Serial port outputs anything when the user presses buttons on the remote control? e.g. would it be possible to control the volume on an Amp with serial input by converting the serial output messages from the panel?
    Many thanks,
    Chris
    Worcester
  6. nigels0
    nigels0
    Sep 7, 2004
    42
    Does anyone actually have the full serial commands for the PW series?
