Panasonic PW6 and Pioneer DVD problems?
Discussion in 'Panasonic TVs Forum' started by ollie501, Aug 28, 2004.
  1. ollie501
    ollie501
    Jul 14, 2003
    1,007
    Dorset, UK
    +25
    I remember reading on here somewhere that the PW6 had problems with Pioneer DVD players.
    I have a Pioneer 575, and was never particularly bothered about the issue, since I didn't have a Panny to go with it.
    However, I have since bought a Toshiba 42WP37, which I understand to be the same panel.
    What I am wondering, is what the actual problem was? I have a very slight banding on component connection from the DVD, and wondered if that was anything to do with it, or just a dodgy lead.
    Any advice gratefully received :lease:
    Ollie
  2. nickc
    nickc
    Oct 31, 2002
    33
    My Pioneer 747 dvd player had a problem with bright scenes when connected via component to my PW6.
    Turned out to be a fault on my plasma, Panasonic fixed it.
    It now works perfectly. :clap:
