Panasonic PW5 progressive scan on DVD problem
Discussion in 'Plasma TVs' started by optikon, Jan 15, 2005.
  1. optikon
    optikon
    I'm new to this forum so excuse me if this question has already been answered, although I have searched in detail.
    I have a Panasonic 42" PW5, which is connected to the TU600 tuner box, which has the DMR65 DVD recorder outputting PAL Progressive to the component inputs on AV4 of the tuner box.
    The picture output from the DVD player is off centre by about 2", when on progressive scan. Also if I put any on screen TV settings on these are also off centre, so I have figured that it has to be the plasma or tuner box to be the problem with processing prog scan.
    Are there any settings to change in the tuner box which can alter the verical positioning of AV4 when on prog scan??
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    2 choices:
    ditch tuner and re configure whole system
    Or just dont use Progscan (limited image improvment)
