Panasonic PW on stand
Discussion in 'Panasonic TVs Forum' started by ben_gb, Dec 3, 2004.
  1. ben_gb
    ben_gb
    Can anyone tell me the height of a Panasonic TH-42PW screen on the 'official' TYST42PA20 table stand, and/or on the AV-Sales slimline desk stand?
    Also, when the screen is mounted on the stand, what is the gap between the table surface and the bottom of the plasma screen glass (ie the bottom of the viewing area)? This is so I know how much space I've got to put a centre speaker there.
    Is anyone using this screen with the Ikea Bonde TV bench with it's "hutch"-style addon unit? Like this:
    http://www.ikea.com/webapp/wcs/stor...16685&langId=-20&parentCats=10104*10173*10407
    Does it fit OK?
    Thanks for your comments!
    Regards,
    Ben
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    The screen is just shorter than the width of the cabinet, the dimensions of the plasma are on the av-sales site if you take a look.
  3. ben_gb
    ben_gb
    Hi Leigh,
    Yup...I found the dimensions of the screen, but not of the plasma AND stands together (the link for the dimensions on the slimline stand page goes to a file not found page).
    Also, I prefer the look of the official Panasonic stand, if it all fits!
    Regards,
    Ben
  4. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    trya a search, as i recall someone asked the very same question last week, or just before that. The av-sales slimline mount has two mouting levels, i expect the panny one doesnt.
  5. johnski
    johnski
    Hi Ben,
    I've got my 42pwd6 on the slimline stand from av-sales, and its mounted to the highest level, the distance from stand to bottom of plasma is 50mm, distance to bottom of viewing area is 97mm
    HTH
    John
  6. r1chuk
    r1chuk
    Jun 10, 2004
    Hello John
    Sorry for jumping on the post, but I've got the exact same unit as ben and need the measurements as follows, because of the possible very tight fit.
    Total height of the 42" on the AV stand
    And exact width
    plus depth of unit
    Appreciate if you can help on this as AV-Sales have yet to reply to these questions for me
  7. johnski
    johnski
    I think i've got the measurements you need.
    Height of 42pwd6 including av-sales stand = 660mm
    Width of av-sales stand ( front ) = 815mm
    Width of av-sales stand ( back ) = 740mm
    Depth of av-sales stand = 300mm
    When plasma is mounted the front of the plasma is 130mm from the front of the av-sales stand
    Hope this is the info you need
    John
