Panasonic PV500 or wait??
Discussion in 'Plasma TVs' started by DJT75, Jun 7, 2005.
  1. DJT75
    DJT75
    May 6, 2005
    9,451
    +2,522
    Have already briefly mentioned this on another thread but thought I'd better start a fresh one.
    Need to wall-mount a 37" flatscreen to make space in my living room. I was convinced I'd buy a 37" LCD a couple of months ago because of the slim build & weight but have since discovered the PQ on SKY (I watch mostly sports) was awful compared to Plasma. So i've decided to go with plasma.
    I had been waiting for the PV500 to come out but am very disappointed with the bulkyness of the whole thing. It's fairly pleasant to look at but would stick out an absolute mile on a wall mount. I like the spec & I like the minimal sized speakers (I hate large framed, massive speakered bulky plasmas).
    Can anyone suggest an alternative available now or in the future I should look out for? Don't want to wait too long, have waited months already. Any links to new upcoming pdfs would be appreciated. thanks
  2. greyhorse
    greyhorse
    Apr 16, 2005
    445
  3. Yousanem
    Yousanem
    No need for the choice. You can order it from AV Sales AND wait ;)
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,055
    2
    4
    137
    Garstang, Lancs
    +1,596
    It is quite big, but it has all the electronics, 2 subwoofers, digital tuner etc built in.
    I am getting around the bulkiness a bit by mounting mine on the wall, sunk in to plasterboard about 4cm, so it will only stick off the wall 10cm.
    You would be looking at a panel version to have the minimal look.
    Some people want the moon on a stick :)
  5. DJT75
    DJT75
    May 6, 2005
    9,451
    +2,522
    I think I'm sold on it by those pictures. I can live with 14cm bulk. Just need JL to Price Match Hi-Spek now....cheers
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,055
    2
    4
    137
    Garstang, Lancs
    +1,596
    You know it makes sense...I would have prefered the PHD8 to be honest, but I can't wait.
  7. Gemz1982
    Gemz1982
    when is that one out?? Is it better then the PV500
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,055
    2
    4
    137
    Garstang, Lancs
    +1,596
    Is is the Pv500 panel but with no speakers/tuner/inputs etc. You have to buy your input boards, should be out Sept ish.
  9. Gemz1982
    Gemz1982
    Is it better getting things separatly like that
