Panasonic PV500 buzz unacceptable
Discussion in 'Plasma TVs' started by WSH, Jun 10, 2005.
  1. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    I went to see the PV500CAB in Currys today with a view of getting one. I have been put off because it has a very loud buzz coming from the rear. The pioneer had less but the Philips was awful.
    The 50" Panasonic (had a 30 in the model) had less buzz than the PV500. Noise is a problem for me. I hate any noise that shouldn't be there. I don't think the PV500 is an option now :(
  2. kevin harrison
    kevin harrison
    Must be duff. My 37" is very quiet.
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,055
    2
    4
    137
    Garstang, Lancs
    +1,596
    My 42" is also very quiet
  4. jackuzi
    jackuzi
    Dec 3, 2001
    253
    16
    South Wales
    :D Maybe it was the female assistant following you around...**cough..love eggs..cough** :D
  5. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    If you put your ear to the left of the back panel is there no buzz?
  6. CaSeBaLL
    CaSeBaLL
    Oct 12, 2004
    10
    NO... there is no BUZZZZZZZZZZ..........
  7. Abbs985uk
    Abbs985uk
    Apr 17, 2005
    59
    Birmingham
    For what its worth there is a buzz from the rear on my 37 PV500, although its on the rear right of the panel, I know its the fan as you can feel the air being blown around. You can tell when it starts up when u power the screen up.
    Was a little concerned at first but having contacted Panasonic and listened to some other PV500 sets I think panasonic were right when they told me that the noise will diminish with usuage. A 37inch screen in JL Solihull didnt make any noise and that has been running for over a month, however, the 42 inch screen they had was making the noise which they had set up the day before i went!
    guess its a case of wait and see
  8. greyhorse
    greyhorse
    Apr 16, 2005
    445
    No buzz from mine
  9. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    I didn't think there is a fan in these.
  10. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,684
    Galactica C.I.C.
    +214
    On some of the panasonics, the buzzing is caused and gets louder when peak whites and very bright images are shown on the screen. This is due to the power supply in the Plasma. I get buzzing on my Viera when very bright images are shown, but it is only noticable when there is no other sound coming from the tv, eg: the silence between ad breaks for one.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Take it out of dynamic mode and the BUZZ will drop significantly
  12. k0rn
    k0rn
    I´ve heard from others that have unacceptable buzz-sounds...
    Luckily, my 37PV500 is really quiet..
  13. pib01
    pib01
    Dec 11, 2002
    52
    littlehampton
    no buzz from my 42pv500
  14. Stokesey
    Stokesey
    Very slight buzz from mine but only when u put ur ear to it!!
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Oh and just to add all Panny HD screens have FANS SD panels dont
  16. Gussie
    Gussie
    Oct 19, 2004
    1,236
    48
    +80
    I believe the new 500B 37",42" and 50" even though they are HD screens do not have fans.
    I remember reading someones report on seeing them at Cebit and commenting on that.
    I could be wrong ...
    Gussie :)
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    hmmtrying to think if the 50PV30 has fans or not.............
  18. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    I could hear the buzzing on the right side of the screen (from my position, so watching the glass), and it's annoying if you start hearing it, returned because of it (the 37pa50, not the hd version) practically all plasma's have it :p
  19. Gussie
    Gussie
    Oct 19, 2004
    1,236
    48
    +80
    It is frustrating that companies with years of expertise cannot or will not design reliably quiet circuitry.
    Yes there WILL be always be some noise - if you put you ear close to the back of the set.
    BUT the fact that the noise can INCREASE when the picture contrast is high and can be clearly heard at normal viewing distance is NOT acceptable in a product costing more than £1.5k.
    Two SD Panasonics (PWD6 and PWD7) I've played with do this.
    Several people have now commented on noise coming from bith the 500 and PA Viera models.
    A brand new HD Samsung panel I played for a few days does this.
    Lots of Pioneers do this.
    Yet an older and a brand new SD Samsung panel does not!
    It MUST be possible to design well specified circuitry that is QUIET but in these days of manufacturers cutting costs to the bone - we may have to tolerate this - but it's galling on something that might cost you over £2000.
    Gussie :)
  20. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    yep,got the buzz as well, but you only hear it when listen out for it. I only hear it when i lean against the rear of the plasma.
    I can live with it, but i still don't understand why such companies with multi million r&d are unable to iron out little annoying glitches!!
  21. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    I get a buzz from my PV500 (42") too. However, I can only hear it if I put my ears right next to the TV. It is a bit more noticeable when the TV is on standby.
  22. greentea
    greentea
    I'm experiencing the same problem, has it quietened down yet?
  23. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,055
    2
    4
    137
    Garstang, Lancs
    +1,596
    I think my PV500 is buzzing :thumbsup:
  24. Kaminsky
    Kaminsky
    Apr 26, 2005
    23
    Just received my 37" on Tuesday. Only a slight buzz noticable if I lean over the top of it. Cant really hear it otherwise. Got it set to Normal mode with brightness/contrast down to about 30%.
  25. greentea
    greentea
    had mine a week, noticable loud hum when unit switches on which seems to decrease to an almost acceptable level after an hour, however its still present at very low volumes, having paid £1750 for the unit if this is the way it remains though I'm happy witht he PQ I'll always being disattisfied :eek:(
  26. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    I honestly haven't noticed a buzz from my 37 inch pv500, instead i have been noticing other issues with the picture, a buzz is the least of my problems. I'll listen out for it when i am watching tonight.
  27. tutu
    tutu
    Apr 28, 2004
    2,217
    48
    +58
    My 42pv500b also has a small hum - it comes from the back (top right). I can only hear it when the unit is in standby, and I am very near the set.
    Using the power switch removes the hum as you would expect. But you would hope for £2k you wouldn't have any!
  28. Avi
    Avi
    Dec 30, 2004
    13,937
    +2,067
    From the US web site re:- TH-42PHD7UY.....
    • Fanless Quiet Operation
  29. orange66
    orange66
    some of this is just plain nuts. I have the 42 inch. If you put the volume on mute and glue you ear to the back of the set you can make out a sound. However you wont be able to hear it and watch the tv on my set at the same time so it really is a pointless thiung to complain about. Now buzzing from a surround amp that makes its way into the speakers, not THAT is something to get angry about.
  30. JonnyR
    JonnyR
    Taken delivery of my 42" today and a buzz can only be heard when listening closely from behind the panel. In short, not a problem.
    What I do have a problem with though is a swirling whistling noise eminating from the right hand speaker. While in no way deafening, its certainly easily discernable, especially with the sound down very low. (I should say regardless of whichever input, cable, picture or sound setting used).
    I noticed another poster mentioning exactly the same problem in an ealier thread, although he didn't follow up with the eventual outcome - i.e. cure or replacement.
    Anyone else had any experience of this small but annoying problem?
